Hi Bud, appreciate the response. Excellent work with the log retrieval topic.
The flight logs (.txt) were uploaded to https://www.phantomhelp.com/LogViewer/2RTMZL18X3NCYAMZJ0AQ/#
(Was shooting my son doing lay-ups and dunks so it’s a wierd flight path).
It seems anyone can also access the Airdata journal with the direct link, and view the HD flight player details - let me know if that can help.
Also the latter part of the DatCon log breakdown shows:
663.811 : [L-API]go_home_check
663.811 : [L-CMD]basic_cmd_table send_id 6
663.811 : [L-API]basic_cmd_go_home
663.812 : [L-N_MIS]Init plan 0 from requester 5 for reason 18. Pre plan 5
663.822 : [L-N_MIS]Exit mis 14. New mis 12
663.822 : [L-N_MIS]send cur mission exit data, mis:0, exit_reason:0.
663.822 : [L-N_MIS]Switch new mis 12 req 5 from mis 14 req 4
663.902 : [L-SDK]app API sub_mode 7 2
663.902 : [L-MIS][NAVI MISSION] req sub_mode: AutoAvoid on
663.902 : [L-SDK][USER]send ack 0x00
663.905 : [L-MIS][SDK] new open GS(cam)
663.905 : [L-MIS]received on/off 2 from dev 2
663.905 : [L-MIS]ack on/off 0 to can
663.913 : [L-MIS][SDK]reset user_emergency_brake by ctrl dev changing
668.284 : [L-FMU/LED]type:0, normal flash action:
668.284 : [L-FMU/LED]c0:0,1;c1:0,1;c2:0,1;c3:2,3;c4:0,1;c5:0,1;c6:0,1;c7:0,1
669.167 : [L-FMU/LED]type:0, normal flash action:
669.167 : [L-FMU/LED]c0:0,15;c1:0,3;c2:0,13;c3:2,3;c4:0,10;c5:0,3;c6:0,10;c7:0,3
681.112 : [L-NS][AHRS],qg obv buffer size[215/270]
690.239 : [L-N_MIS]req abort all for App Go-Home Exit
690.245 : [L-N_MIS]send cur mission exit data, mis:0, exit_reason:0.
690.245 : [L-N_MIS]Switch new mis 3 req 2 from mis 25 req 17
690.245 : [L-FLYMODE]SWITCH2HOVER!
690.860 : [L-MIS][SDK] new open GS(cam)
690.860 : [L-MIS]received on/off 1 from dev 2
690.860 : [L-MIS]ack on/off 0 to can
690.887 : [L-N_MIS]Exit mis 3. New mis 14
690.887 : [L-N_MIS]send cur mission exit data, mis:0, exit_reason:0.
690.887 : [L-N_MIS]Switch new mis 14 req 4 from mis 3 req 2
690.890 : [L-MIS][SDK] new open GS(cam)
690.890 : [L-MIS]received on/off 1 from dev 2
690.890 : [L-MIS]ack on/off 0 to can
690.910 : [L-MIS][SDK] new open GS(cam)
690.910 : [L-MIS]received on/off 1 from dev 2
690.910 : [L-MIS]ack on/off 0 to can
690.920 : [L-SDK]app API sub_mode 7 2
690.920 : [L-MIS][NAVI MISSION] req sub_mode: AutoAvoid on
690.921 : [L-SDK][USER]send ack 0x00
690.938 : [L-SDK]app API sub_mode 7 2
690.938 : [L-MIS][NAVI MISSION] req sub_mode: AutoAvoid on
690.938 : [L-SDK][USER]send ack 0x00
709.711 : [L-N_MIS]Init plan 0 from requester 6 for reason 12. Pre plan 5
709.721 : [L-N_MIS]Exit mis 14. New mis 12
709.721 : [L-N_MIS]send cur mission exit data, mis:0, exit_reason:0.
709.721 : [L-N_MIS]Switch new mis 12 req 6 from mis 14 req 4
709.809 : [L-SDK]app API sub_mode 7 2
709.809 : [L-MIS][NAVI MISSION] req sub_mode: AutoAvoid on
709.810 : [L-SDK][USER]send ack 0x00
709.819 : [L-MIS][SDK] new open GS(cam)
709.819 : [L-MIS]received on/off 2 from dev 2
709.819 : [L-MIS]ack on/off 0 to can
709.832 : [L-MIS][SDK]reset user_emergency_brake by ctrl dev changing
717.352 : [L-FDI][CTRL]: fault on , tilt_ctrl_fail
717.352 : [L-CFG]PM:[fc_fault_log_error_set_status] “fault_log_info.index” to 35||
717.352 : [L-CFG]PM:[fc_fault_log_error_set_status] “fault_log_info.reason” to 4||
717.352 : [L-CFG]PM:[fc_fault_log_error_set_status] “fault_log_info.flag” to 1||
717.352 : {tska}INFO:fc fault log error reason: 0x044, flylog index: 35||
717.371 : [L-RC]craft ctrl failed!!!
717.390 : [L-CFG]PM:[ack_cb_fc_fault_log] “fault_log_info.flag” to 0||
717.390 : {tska}INFO:fc fault log ack ok!||
717.493 : [L-FDI][CTRL]: fault off, tilt_ctrl_fail
717.572 : [L-N_MIS]Exit mis 12. New mis 11
717.572 : [L-N_MIS]send cur mission exit data, mis:0, exit_reason:0.
717.572 : [L-N_MIS]Switch new mis 11 req 6 from mis 12 req 6
717.573 : [L-FDI][CTRL]: fault on , tilt_ctrl_fail
717.713 : [L-FDI][CTRL]: fault off, tilt_ctrl_fail
717.733 : [L-FDI][CTRL]: fault on , tilt_ctrl_fail
717.894 : [L-FDI][CTRL]: fault off, tilt_ctrl_fail
718.054 : [L-FDI][CTRL]: fault on , impact_in_air
718.054 : [L-CFG]PM:[fc_fault_log_error_set_status] “fault_log_info.reason” to 2||
718.054 : [L-CFG]PM:[fc_fault_log_error_set_status] “fault_log_info.flag” to 1||
718.054 : {tska}INFO:fc fault log error reason: 0x042, flylog index: 35||
718.072 : [L-CFG]PM:[ack_cb_fc_fault_log] “fault_log_info.flag” to 0||
718.072 : {tska}INFO:fc fault log ack ok!||
718.094 : [L-FDI][CTRL]: fault on , tilt_ctrl_fail
718.153 : [L-FDI][CTRL]: fault off, impact_in_air
718.172 : [L-GIMBAL]reset gimbal acked len 1 buf 0, cb_type=0
718.235 : [L-FDI][CTRL]: fault off, tilt_ctrl_fail
718.333 : [L-FDI][CTRL]: fault on , tilt_ctrl_fail
Cheers, Maz
