I have the Mini 2 and I have not flown around cell towers in close proximetry but there are lots of video of folk flyng in circles around the towers… Check YouTube, I would not play chicken with them, but under normal circumstance, it should not be a problem…
Your first priority should be safely taking off and landing your drone. Learn to fly it by sight, not by watching the screen, you need to be able to fly it correctly whether you are flying it away from you or towards yourself.
I am thinking that you are in the USA so, I’ll respond that way…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a “certified” Unmanned Aerial Vehicle (UAV) Pilot.
https://faadronezone.faa.gov/#/
There are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
