Help people…the drone i have Mavic Pro.has only been flown around 8…10 times…bought off someone who was a bit wary of using it.It hasnt been crashed or anything…I have done all gimbal calibrations etc. and compass…no problems…
However…no matter what i do…the IMU will not calibrate…gets to around 30% on 1sr attempt…then error 50…
Ive tried lots of different hacks…ie, tapping underneath…starting on its end…rebooting…it just wont play…Help.!!
Thanks…yes i have numerous times.s.not tried by connecting to wi fi…though…will give it a go…and let you know.!!
The connecting to Wi-Fi part is not relevant here. Completing the process of “calibrating” the drone in the upright position and then followed up with a regular calibration is what fixes the problem for many people.
OK>>tried resetting in upright position umpteen times…still wont calibrate.!
It sounds like you’ve tried all of the common fixes.
Did the seller send it to you in this condition? If so, you could return it and buy a Mavic Pro that has no known issues.
