Follow these instructions to locate the Litchi CSV flight logs on your mobile device:
For Apple mobile devices, follow these instructions to retrieve your Litchi CSV flight logs from iTunes.
Note: You’ll want to select Litchi in the listed apps and retrieve the flight logs from the flightlogs folder.
For Android mobile devices, connect your mobile device to a computer via a USB cable and go to the “LitchiApp/flightlogs” folder.
Note: If the log files are not visible or you’re not able to find a specific log file that should be there, then install and run SD Refresh or restart your mobile device.
