Hi, is there anyway to download the flight log as a kmz?
Are you able to use a KML file instead? If so, right click the flight log in the main Flight Reader window and choose “Open Log Folder”. You’ll find the KML file there.
No I am using a txt file.
And are you using Flight Reader to process your TXT flight logs?
Yes I am.
Perfect. So, after you process a TXT flight log and it appears in the main Flight Reader window, right click that flight log and choose “Open Log Folder”. In that folder, you’ll find a KML file. The only difference between a KML and KMZ is the KMZ contains a compressed (zipped) KML file. Both can be opened in Google Earth and likely other KML viewers.
