Follow these instructions to delete the flight logs from the Mavic Pro’s internal memory:
Note: You’ll need an FTP client to connect to the Mavic Pro and delete the flight log files. These instructions show how to perform this procedure using FileZilla.
1) Connect a micro USB cable between the micro USB port on the side of the Mavic Pro to a USB port on your computer.
2) In FileZilla, select “File” → “Site Manager…” from the top menu and create a new site with the following settings:
Note: The username and password are both “nouser”.
4) In the “Remote site” pane, navigate to the “/blackbox/flyctrl” directory by double clicking the “blackbox” directory and then double clicking the “flyctrl” directory. You should then see the contents of the “/blackbox/flyctrl” directory
Hi, this looked so promising. I wanted to try it out on my Mavic 2 Pro. It won’t connect with the settings given. I get the following message: Connection attempt failed with “ECONNREFUSED - Connection refused by server” Is there a password associated with this? I see something in the password box but it is blanked out. Any pointers would be appreciated.
Bummer, no solution for the Mavic 2 yet then. I hope someone comes up with a way to get rid of the logs. Considering that every time one flies one of these beyond line of sight visual control limits you are committing a federal crime and that all the evidence is there in the logs, I would like to clean it out once in a while. It is only a matter of time before the feds will go to DJI for the data and go after anyone flying, say, more than 1000 feet from take off point. I was going to retire my Pixhawk birds since I like the Mavic 2 so much but now I will be keeping them around. At least with Pixhawk I have complete control of my data.
Hi, Instead of deleting my internal flight logs. I used your method to backup my flight logs. However, the downloaded .DAT files are found to be encrypted and cannot be view. Anyway, to view my flight logs?
I’ve tried to connect the Mavic Pro using the above method but it won’t even connect.
Is the IP address user name and password the same for all Mavic’s?
I tried to connect to my Phantom 4 adv+ and it works without fail. The IP adress is an typical vor internal networks and should work on every coopter.
First of all every new owner could read the log files with the DJI Assistant App. If have done it as well and could see any flight of the previous owner. The log files could be analyzed on this webpage. Just load it up and you will get any detail including temperature during the flight.
In my mind this is not a way to ignore data safety in Europe.
