Hi. I'm starting over after a long break
Hi. Haven’t flown in a couple years or so. I’m trying to learn what has changed. John
Welcome to the forum! :slight_smile:
What are you flying?
I just got a used P4 Pro V2.0. It cleaned up pretty nice and it’s updated and registered to me.
Waiting to fly until I’m sure of the changes in FAA requirements, etc.
Firmware version 01.00.70.17 (released on 11/23/2023) will enable RID on your drone. As long as you have that firmware installed, you’re good to go.
If you are in the USA, there are a couple of Legal Things you may need to do… If you live outside the USA, then It’s all on you to learn your legal obligations…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. If your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
Since you live somewhere, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Fly On and Fly Safe…
I’ll start a thread on B4UFLY. I’m missing something there.
B4UFLY is the simple App for drone operators to check airspace and local advisories before taking flight. It is not a Web Site to post threads.
Thanks. Looks like I’m overthinking this. Doesn’t look like I even need an app. If I go to the UASidekick website and check my location for restrictions, that counts for my required due diligence before I fly?
I also looked at a map at DJI FlySafe. That doesn’t count? What is DJI FlySafe good for?
Yes, that’s one of the approved service providers. You can also use the other service providers listed here.
It’s supposed to notify you of nearby flight restrictions. However, you should still scout out any unfamiliar areas before flying. The FAA won’t award points for effort if you inadvertently enter a no-fly zone.
Sorry, but Due Diligence is to not enter controlled airspace without authorizations and notifications as required by the FAA, not hazard manned aircraft, not hazard people, animals, or property, and so much more…
When your drone takes off, the FAA no longer considers it a toy and it deserves all the respect of any aircraft.
I would not use it for anything… I have logged on in the past when I was flying in a Restricted Zone and I needed DJI to unlock the area. Since they upgraded the fly safe database, I have not had to use it, but I am sure at some point I may need them again, but you can only get an area unlocked with the proper authorizations…
Here is my list of go to applications…
Air Control for viewing the Air Space for controlled areas and height restrictions.
Air Aware for viewing the Air Space for controlled areas and height restrictions.
Windy.Com (works on PCs, Android, and iOS…) for my weather reports
UAV Forecast for more weather information
I flew for a few minutes this evening. Felt GREAT!
Thanks for the support. I’ve used this site extensively in the past. Thanks for that too.
Here are two of my favorites:
I consider these indispensible. Great work.
