Hi from WA, I am retired mechanic, main hobby photography, and my new extension to that is a drone in a box I havent flown yet!
So, don’t hold back, what’s in the box?
I have a Mavic mini SE.
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all.
Do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Turn on the drone and watch it come to “life.” Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first time…
Lift off, 4-5 feet (1-1/2 meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
The following YouTube Video by Jeven Dovey is well worth watching and you might even subscribe to his channel…
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User’s Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
Happy and Safe Droning…
Thankyou for the wealth of knowledge, very much appreciated, have to wait for a couple of days, weather is real ugly here at the moment, ![]()
The weather is Ugly, Good! It will give you plenty of time to read the manual and watch those Good Instructional YouTube Videos and those Bad YouTube Blooper Videos… and make yourself a “Remove Before Flight” Ribbon for the Gimbal Cover and fasten it on (tape or glue).
Hi Adberton! You’ll have lots of fun and create some wonderful memories!
