Hello from The Netherlands
I’m a new Pilot with a DJI Mini 5 Pro.
**Welcome from the Hampton Roads area of Virginia, USA.
If you have any questions, just ask; if I do not know the answer, I’ll make one up… L :grin: L . . .
Your journey is just beginning.
Good Luck and Enjoy!
Thank you!
I’ve just did my Drone-exams and got my license. At the moment we have bad weather in The Netherlands, but next weekend I hope to fly my first meters with my DJI Mini 5 Pro.
I bet I’ll have some questions in the near future :wink:.
Stay Safe!
Plug in your phone/tablet into your controller; turn on the Controller and the Drone App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, “Home point Updated.”
Fly On and Fly Safe…
Thanks for the tips! I’ll follow them.
**When you do go out to fly, be prepared for spectators and even some folks coming over to ask questions… I will not tell you the questions, only the answers. But the questions will be apparent from the answers… :rofl:
The Seven Answers are:…
                                   1. It's a Quadcopter…
                                   2. Yes, it has a camera…
                                   3.  Yes, it's very expensive…
                                   4. Very high…
                                   5. Very far…
                                   6. About 35-MPH…  and
                                   7. No, you can't fly it…**
