Got a DJI Mini 2 SE as a gift. Of course my android phone wasn’t compatible. If you need a great cheap android device, the Lenovo M10 Plus runs DJI Fly great so far. Also recommend the FPV Tosky controller tablet mounting bracket. Both at Amazon.
Welcome to the forum ![]()
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Fly On and Fly Safe…
Obtained the Trust certificate. Looking into part 107.
Thanks.
If you plan to make money (real estate photos, roof inspections, etc…), it is a must… I have my part 107, not to make money but to be able to fly in my own yard and elsewhere. I live in a very controlled airspace area, internation airport, Air Force Base, and Army Airfield, and a Naval Air Station. To fly in almost anywhere, I need an FAA Authorization from the FAADroneZone.com (Go there and look around, there is a lot to learn…).
Additionally, the part 107 lets me fly in locations that a Rec Pilot (TRUST) may not be able to fly…
Since you live in Chicago, it is also a tightly controlled area and you might also need an FAA Authorization to fly in various areas, Always check with the B4UFly App to see if you are legal…
