Hello from Bulgaria :)
Hi there. I am literally an amateur drone pilot, alhtough I fly for several years already.
I have some videos on my YouTube channel (most of them aren’t about flying with drones).
DJI Mini 2 owner currently, I also have the KF102 chinese drone, but it is quite unreliable ! … :wink:
Owned also the DJI Mini SE, but eventually sold it.
Welcome from the Hampton Roads area of Virginia,
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, “Home point Updated.”
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
I actually had my old phone number printed on a piece of paper glued to the drone, and I recently removed it, but I might as well print my new number of course. Thanks for the advice.
By The Way - I am impressed how much text you wrote just to say “Hello”… :slight_smile:
Yes, I paid a lot of money for this drone, that was in 2023… I never crashed it. Not saying that I am a Pro of course.
Welcome to the forum @Freeman! :slight_smile:
