Hello,
I’m not sure if it was a firmware update that caused the issue or what :-/
Currently my goggles 3 lights will flash until the battery dies
Everything Seams to function normally while powered up and in use. But when I do the click then click and hold to power down , that power down and the normal sound is Heard. But then the farthest to the right light flashes and then the lights that indicate what the charge level is flash. This keeps happening until the battery dies.
I’ve tried rolling back the firmware via the pc app, then upgrading again.
I’ve reset to factory from the goggles menus
No luck :-/
Has anyone else seen this?
Do the goggles power off if you press and hold the power button for 10 seconds?
They do power all the way off of I hold it down for 10 sec
But then they will only power back on if I apply the usb c charge cable and push power.
After powered off, what happens when you quickly press and release the power button?
Nothing, acts as if it’s dead
That’s definitely not the expected behavior. Have you tried asking DJI Support?
