Today, I received a gimbal error saying load was too high and check to ensure the gimbal clamp was removed. Problem is it was removed. The gimbal is continuously trying to reset itself like when you first start it up. Also I have no control of the gimbal from the controller. All the rubber bands are connected and the gimbal moves freely manually so it doesn’t seem to be bound up or anything. Updated firmware and still no help. Any ideas? It almost seems like a software issue, so i am also wondering if there is a factory reset procedure for the drone itself. HELP!!!
Gimbal flat cable is broken, i replace the cabLe by myself and it works fine now
