Gimbal not working
My mavic pro has been working well for past few weeks since ribbon repair.
Last few flights been great.
Took it out yesterday and message saying gimbal motor load too high, check cover is removed.
Cover is removed but just won’t calibrate gimbal or adjust.
Any ideas/suggestions?
It’s not been crashed or damaged, simply put away after each flight with gimbal lock and cover used every time.
Video showing what it’s doing https://youtu.be/YPrAxmhqtzI?si=IXHXiktJTSc6k9Pe
IMU and gyro calibrate fine, video image is all good.
I’m at a loss to what could be the problem.
Hi. Did you find a solution? I have a similar problem.
