Have any of you Phantom Pro owners out there have taken off the main lens cover to switch it with a UV or Polarizer lens? It looks like it could be a daunting task with damaging the gimbal. Anybody?? Thx, Joel
david
June 28, 2019, 12:16am
#2
Use a pair of thin rubber gloves and it’s not too hard to control and not damage the gimble
cookedlinlh
I’ll take that advice. Thx, Joel
You can find some others tips that’ll help with removing that filter here:
The ring on the Mavic Air camera always feel crazy tight the first time it’s removed. Here are some tips that should help you easily remove it:
Position three fingers evenly around the outside of the ring (so you can apply even pressure) like this:
[Filter-Removal-Finger-Position]
Grip the ring as loosely as possible. If you grip the ring with a lot of force and/or attempt to use tools to remove it, it likely won’t budge and you might damage it.
Hold the camera steady with your oth…
