I released a new version today with the following changes:
ADDED: Added incomplete records that sometimes appear at the end of DJI TXT flight logs. While these records are often missing key data, the data they expose could be useful for troubleshooting purposes.
FIXED: Resolved a calculation issue that was sometimes allowing incorrect âOSD.hSpeedâ values to be shown for some operating systems and/or architectures due to the way the .NET math library performs calculations.
I released a new version of my log viewer today with the following changes:
ADDED: Added support for processing Mavic 3 Classic flight logs.
ADDED: Added serial number fields âSERIAL.batteryâ, âSERIAL.battery2â, âSERIAL.cameraâ, âSERIAL.camera2â, âSERIAL.flightControllerâ, âSERIAL.gimbalâ, âSERIAL.gimbal2â, âSERIAL.rcâ, and âSERIAL.ssdâ.
ADDED: Added âDETAILS.guidâ unique id field to allow flight logs to be uniquely identified after processing.
ADDED: Added âRC.mode.RAWâ field to display the numeric âRC.modeâ field value (useful in cases where the âRC.modeâ field displays a letter value).
ADDED: Added missing âMasterShotsâ, âNormalâ, and âSportâ flight modes.
CHANGED: Modified the âCAMERA.isPhotoâ field to display âTrueâ from the time the aircraft starts capturing a photo until that process completes (that usually takes 1-2 seconds).
CHANGED: The âRC.modeâ field displays âCâ, âNâ, or âSâ to show the position of the flight mode switch when flying with the DJI RC Pro remote controller.
CHANGED: When flying with the DJI Fly Obstacle Avoidance Action set to âBypassâ (which enables APAS), the âOSD.flycStateâ flight mode field will display âP-GPS (Bypass)â. When set to âBrakeâ, the âOSD.flycStateâ field will display âP-GPS (Brake)â. And when set to âOffâ, the âOSD.flycStateâ field wil display âP-GPSâ.
ADDED: Added support for processing Phantom 3 SE flight logs.
ADDED: When viewing flight logs for drones with two batteries, the âBATTERYâ fields will now be split out into âBATTERY1â and âBATTERY2â fields to display the data for both batteries.
CHANGED: The âBATTERY.timesChargedâ field is now being populated for most drones.
CHANGED: Removed âCUSTOM.date [local]â and âCUSTOM.updateTime [local]â fields from the CSV log. These fields were showing the date/time in EST (the time zone of my web server).
CHANGED: Added âCUSTOM.date [UTC]â and âCUSTOM.updateTime [UTC]â fields to the CSV log to show the date/time in UTC.
CHANGED: Added âCUSTOM.dateâ and âCUSTOM.updateTimeâ fields to the CSV log to show the date/time at the flight location.
FIXED: Resolved an issue that was causing times in the âCUSTOM.updateTimeâ fields to sometimes be off by several milliseconds.
CHANGED: Changed the OSD.hSpeed calculation to use the OSD.xSpeed and OSD.ySpeed instead of calculating the speed based on the changes between the longitude and latitude location changes.
CHANGED: Increased speed fields to 6 decimal places for added precision.
