Flight Reader Web 2026.19 released
A new version of Flight Reader Web is available. Release 2026.19 includes the following changes:
  • Added support for processing Skyrover S1 and X1 flight logs and importing them from connected mobile devices.
  • Added new log fields to show firmware versions for internal components: FIRMWARE.battery, FIRMWARE.battery2, FIRMWARE.camera, FIRMWARE.camera2, FIRMWARE.flightController, FIRMWARE.gimbal, FIRMWARE.gimbal2, FIRMWARE.rc
  • Added a new OSD.tiltDirection log field to show the direction the aircraft is leaning based on its pitch and roll angles.
  • Added new log fields to show the wind direction in degrees: WEATHER.windDirectionDegrees, WEATHER.windRelativeDirectionDegrees
  • The following new RTK log fields have been added to show the positioning status, aircraft heading, position uncertainty, and satellite counts for both aircraft receivers and the base station:
    • RTK.positioning: Indicates the RTK positioning solution, reflecting the level of positioning accuracy and reliability of GNSS.
    • RTK.sdHorizontal [m]: The estimated horizontal position uncertainty (in meters).
    • RTK.sdHorizontal [cm]: The estimated horizontal position uncertainty (in centimeters).
    • RTK.sdHorizontal [mm]: The estimated horizontal position uncertainty (in millimeters).
    • RTK.sdLatitude [m]: The estimated latitude (north/south) position uncertainty (in meters).
    • RTK.sdLatitude [cm]: The estimated latitude (north/south) position uncertainty (in centimeters).
    • RTK.sdLatitude [mm]: The estimated latitude (north/south) position uncertainty (in millimeters).
    • RTK.sdLongitude [m]: The estimated longitude (east/west) position uncertainty (in meters).
    • RTK.sdLongitude [cm]: The estimated longitude (east/west) position uncertainty (in centimeters).
    • RTK.sdLongitude [mm]: The estimated longitude (east/west) position uncertainty (in millimeters).
    • RTK.sdVertical [m]: The estimated vertical position uncertainty (in meters).
    • RTK.sdVertical [cm]: The estimated vertical position uncertainty (in centimeters).
    • RTK.sdVertical [mm]: The estimated vertical position uncertainty (in millimeters).
    • RTK.aircraftHeading: The aircraft’s heading in degrees clockwise from north, as determined by the RTK positioning system.
    • RTK.aircraftGpsCount1: The number of GPS satellites reported by mobile RTK receiver 1.
    • RTK.aircraftGpsCount2: The number of GPS satellites reported by mobile RTK receiver 2.
    • RTK.aircraftBeiDouCount1: The number of BeiDou satellites reported by mobile RTK receiver 1.
    • RTK.aircraftBeiDouCount2: The number of BeiDou satellites reported by mobile RTK receiver 2.
    • RTK.aircraftGlonassCount1: The number of GLONASS satellites reported by mobile RTK receiver 1.
    • RTK.aircraftGlonassCount2: The number of GLONASS satellites reported by mobile RTK receiver 2.
    • RTK.aircraftGalileoCount1: The number of Galileo satellites reported by mobile RTK receiver 1.
    • RTK.aircraftGalileoCount2: The number of Galileo satellites reported by mobile RTK receiver 2.
    • RTK.aircraftQzssCount1: The number of QZSS satellites reported by mobile RTK receiver 1.
    • RTK.aircraftQzssCount2: The number of QZSS satellites reported by mobile RTK receiver 2.
    • RTK.baseStationGpsCount: The number of GPS satellites reported by the RTK base station.
    • RTK.baseStationBeiDouCount: The number of BeiDou satellites reported by the RTK base station.
    • RTK.baseStationGlonassCount: The number of GLONASS satellites reported by the RTK base station.
    • RTK.baseStationGalileoCount: The number of Galileo satellites reported by the RTK base station.
    • RTK.baseStationQzssCount: The number of QZSS satellites reported by the RTK base station.
  • Improved Flight Polygon KML generation performance when processing flight logs with densely recorded flight paths or repeated coordinate sequences.
