A new version of Flight Reader Desktop is available. Release 1.8.45 includes the following changes:
Added support for processing Skyrover S1 and X1 flight logs and importing them from connected mobile devices.
Added new log fields to show firmware versions for internal components: FIRMWARE.battery, FIRMWARE.battery2, FIRMWARE.camera, FIRMWARE.camera2, FIRMWARE.flightController, FIRMWARE.gimbal, FIRMWARE.gimbal2, FIRMWARE.rc
Added a new GIMBAL.tilt log field to show the gimbal tilt angle relative to the aircraft.
Added a new OSD.tiltDirection log field to show the direction the aircraft is leaning based on its pitch and roll angles.
Added new log fields to show the wind direction in degrees: WEATHER.windDirectionDegrees, WEATHER.windRelativeDirectionDegrees
The following new RTK log fields have been added to show the positioning status, aircraft heading, position uncertainty, and satellite counts for both aircraft receivers and the base station:
RTK.positioning: Indicates the RTK positioning solution, reflecting the level of positioning accuracy and reliability of GNSS.
RTK.sdHorizontal [m]: The estimated horizontal position uncertainty (in meters).
RTK.sdHorizontal [cm]: The estimated horizontal position uncertainty (in centimeters).
RTK.sdHorizontal [mm]: The estimated horizontal position uncertainty (in millimeters).
RTK.sdLatitude [m]: The estimated latitude (north/south) position uncertainty (in meters).
RTK.sdLatitude [cm]: The estimated latitude (north/south) position uncertainty (in centimeters).
RTK.sdLatitude [mm]: The estimated latitude (north/south) position uncertainty (in millimeters).
RTK.sdLongitude [m]: The estimated longitude (east/west) position uncertainty (in meters).
RTK.sdLongitude [cm]: The estimated longitude (east/west) position uncertainty (in centimeters).
RTK.sdLongitude [mm]: The estimated longitude (east/west) position uncertainty (in millimeters).
RTK.sdVertical [m]: The estimated vertical position uncertainty (in meters).
RTK.sdVertical [cm]: The estimated vertical position uncertainty (in centimeters).
RTK.sdVertical [mm]: The estimated vertical position uncertainty (in millimeters).
RTK.aircraftHeading: The aircraft’s heading in degrees clockwise from north, as determined by the RTK positioning system.
RTK.aircraftGpsCount1: The number of GPS satellites reported by mobile RTK receiver 1.
RTK.aircraftGpsCount2: The number of GPS satellites reported by mobile RTK receiver 2.
RTK.aircraftBeiDouCount1: The number of BeiDou satellites reported by mobile RTK receiver 1.
RTK.aircraftBeiDouCount2: The number of BeiDou satellites reported by mobile RTK receiver 2.
RTK.aircraftGlonassCount1: The number of GLONASS satellites reported by mobile RTK receiver 1.
RTK.aircraftGlonassCount2: The number of GLONASS satellites reported by mobile RTK receiver 2.
RTK.aircraftGalileoCount1: The number of Galileo satellites reported by mobile RTK receiver 1.
RTK.aircraftGalileoCount2: The number of Galileo satellites reported by mobile RTK receiver 2.
RTK.aircraftQzssCount1: The number of QZSS satellites reported by mobile RTK receiver 1.
RTK.aircraftQzssCount2: The number of QZSS satellites reported by mobile RTK receiver 2.
RTK.baseStationGpsCount: The number of GPS satellites reported by the RTK base station.
RTK.baseStationBeiDouCount: The number of BeiDou satellites reported by the RTK base station.
RTK.baseStationGlonassCount: The number of GLONASS satellites reported by the RTK base station.
RTK.baseStationGalileoCount: The number of Galileo satellites reported by the RTK base station.
RTK.baseStationQzssCount: The number of QZSS satellites reported by the RTK base station.
Improved Flight Polygon KML generation performance when processing flight logs with densely recorded flight paths or repeated coordinate sequences.
