Flight Reader API 2026.11 released
A new version of Flight Reader API has been deployed. Release 2026.11 includes the following changes:
  • Added support for processing Skyrover S1 and X1 flight logs.
  • Added new log fields to show firmware versions for internal components: FIRMWARE.battery, FIRMWARE.battery2, FIRMWARE.camera, FIRMWARE.camera2, FIRMWARE.flightController, FIRMWARE.gimbal, FIRMWARE.gimbal2, FIRMWARE.rc
  • Added a new OSD.tiltDirection log field to show the direction the aircraft is leaning based on its pitch and roll angles.
  • Added new log fields to show the wind direction in degrees: WEATHER.windDirectionDegrees, WEATHER.windRelativeDirectionDegrees
  • The following new RTK log fields have been added to show the positioning status, aircraft heading, ellipsoidal height, geoid height, position uncertainty, and satellite counts for both aircraft receivers and the base station:
    • RTK.positioning Indicates the RTK positioning solution, reflecting the level of positioning
      accuracy and reliability of GNSS.
    • RTK.sdHorizontal [m] The estimated horizontal position uncertainty (in meters).
    • RTK.sdHorizontal [cm] The estimated horizontal position uncertainty (in centimeters).
    • RTK.sdHorizontal [mm] The estimated horizontal position uncertainty (in millimeters).
    • RTK.sdLatitude [m] The estimated latitude (north/south) position uncertainty (in meters).
    • RTK.sdLatitude [cm] The estimated latitude (north/south) position uncertainty (in centimeters).
    • RTK.sdLatitude [mm] The estimated latitude (north/south) position uncertainty (in millimeters).
    • RTK.sdLongitude [m] The estimated longitude (east/west) position uncertainty (in meters).
    • RTK.sdLongitude [cm] The estimated longitude (east/west) position uncertainty (in centimeters).
    • RTK.sdLongitude [mm] The estimated longitude (east/west) position uncertainty (in millimeters).
    • RTK.sdVertical [m] The estimated vertical position uncertainty (in meters).
    • RTK.sdVertical [cm] The estimated vertical position uncertainty (in centimeters).
    • RTK.sdVertical [mm] The estimated vertical position uncertainty (in millimeters).
    • RTK.aircraftHeading The aircraft’s heading in degrees clockwise from north, as determined by the RTK positioning system.
    • RTK.aircraftEllipsoidalHeight [ft] The aircraft’s altitude above the WGS84 ellipsoid (in feet), as reported by the RTK module.
    • RTK.aircraftEllipsoidalHeight [m] The aircraft’s altitude above the WGS84 ellipsoid (in meters), as reported by the RTK module.
    • RTK.aircraftGeoidHeight [ft] The geoid height offset (in feet) at the aircraft’s location based on the EGM2008-1 model.
    • RTK.aircraftGeoidHeight [m] The geoid height offset (in meters) at the aircraft’s location based on the EGM2008-1 model.
    • RTK.aircraftGpsCount1 The number of GPS satellites reported by mobile RTK receiver 1.
    • RTK.aircraftGpsCount2 The number of GPS satellites reported by mobile RTK receiver 2.
    • RTK.aircraftBeiDouCount1 The number of BeiDou satellites reported by mobile RTK receiver 1.
    • RTK.aircraftBeiDouCount2 The number of BeiDou satellites reported by mobile RTK receiver 2.
    • RTK.aircraftGlonassCount1 The number of GLONASS satellites reported by mobile RTK receiver 1.
    • RTK.aircraftGlonassCount2 The number of GLONASS satellites reported by mobile RTK receiver 2.
    • RTK.aircraftGalileoCount1 The number of Galileo satellites reported by mobile RTK receiver 1.
    • RTK.aircraftGalileoCount2 The number of Galileo satellites reported by mobile RTK receiver 2.
    • RTK.aircraftQzssCount1 The number of QZSS satellites reported by mobile RTK receiver 1.
    • RTK.aircraftQzssCount2 The number of QZSS satellites reported by mobile RTK receiver 2.
    • RTK.baseStationGpsCount The number of GPS satellites reported by the RTK base station.
    • RTK.baseStationBeiDouCount The number of BeiDou satellites reported by the RTK base station.
    • RTK.baseStationGlonassCount The number of GLONASS satellites reported by the RTK base station.
    • RTK.baseStationGalileoCount The number of Galileo satellites reported by the RTK base station.
    • RTK.baseStationQzssCount The number of QZSS satellites reported by the RTK base station.
  • Added a new GIMBAL.tilt log field to show the gimbal’s tilt angle (in degrees) relative to the aircraft, including automatic adjustments that keep the camera steady as the aircraft pitches forward or backward.
  • Added DELETE /v1/accounts/dji/cloud/{id} and DELETE /v1/accounts/dji/smartfarm/{id} to remove saved DJI Cloud and DJI SmartFarm account credentials from your Flight Reader API account.
  • Added a Retry-After header to POST /v1/accounts/dji/cloud and POST /v1/accounts/dji/smartfarm responses with HTTP status 429 when DJI limits sign-in attempts.
  • Corrected error responses for invalid DJI credentials when signing in through POST /v1/accounts/dji/cloud or POST /v1/accounts/dji/smartfarm, or downloading flight logs through GET /v1/files/flight-logs/{id}/{filename}. The API now returns HTTP status 401 so applications can prompt users to reconnect their DJI account.
