A new version of Flight Reader API has been deployed. Release 2024.5 includes the following changes:
Added the following new fields:
OSD_DirectionOfTravel
The direction (between 0 to 360 degrees) the aircraft is traveling based on the change in latitude and longitude. -
WEATHER_IsFacingWind
When true, the front of the aircraft is currently facing a headwind. -
WEATHER_IsFlyingIntoWind
When true, the aircraft is currently flying into a headwind. -
WEATHER_WindDirection
The cardinal direction the wind is blowing from at the aircraft’s current location. -
WEATHER_WindRelativeDirection
The cardinal direction the wind is blowing from relative to the direction the aircraft is currently facing. For example, an East wind would be blowing toward the right side of the aircraft. -
WEATHER_WindSpeedKmh
The wind speed (in km/h) at the aircraft’s current location. -
WEATHER_WindSpeedMaxKmh
Maximum wind speed (in km/h) at the aircraft’s current location (so far in the flight log). -
WEATHER_WindSpeedMaxMph
Maximum wind speed (in MPH) at the aircraft’s current location (so far in the flight log). -
WEATHER_WindSpeedMaxMS
Maximum wind speed (in m/s) at the aircraft’s current location (so far in the flight log). -
WEATHER_WindSpeedMph
The wind speed (in MPH) at the aircraft’s current location. -
WEATHER_WindSpeedMS
The wind speed (in m/s) at the aircraft’s current location. -
WEATHER_WindStrength
Calm, Moderate, or Strong to indicate the wind strength at the aircraft’s current location.
