A new version of Flight Reader API has been deployed. Release 2024.4 includes the following changes:
The RTK_BaseStationAltitudeF and RTK_BaseStationAltitudeM fields have been updated to display a value for negative altitudes too. The previous API release was discarding negative values.
Added the following new fields:
BATTERY1_VoltageCellDeviation (BATTERY_VoltageCellDeviation)
The current difference in voltage levels among the individual battery cells. -
BATTERY1_VoltageCellDeviationMax (or BATTERY_VoltageCellDeviationMax)
The maximum battery cell voltage deviation (in volts) so far in the flight log. -
BATTERY2_VoltageCellDeviation
BATTERY2_VoltageCellDeviationMax
RTK_AircraftAltitudeF
The aircraft’s current altitude (in feet) as reported by the RTK module. -
RTK_AircraftAltitudeM
The aircraft’s current altitude (in meters) as reported by the RTK module. -
RTK_AircraftHeightF
The aircraft’s current height (in feet) above the takeoff location as reported by the RTK module. -
RTK_AircraftHeightM
The aircraft’s current height (in meters) above the takeoff location as reported by the RTK module. -
RTK_AircraftHeightMaxF
The aircraft’s maximum height (in feet) above the takeoff location (so far in the flight log) as reported by the RTK module. -
RTK_AircraftHeightMaxM
The aircraft’s maximum height (in meters) above the takeoff location (so far in the flight log) as reported by the RTK module.
