Flight Reader 1.8.23 released
A new version of Flight Reader is available. Release 1.8.23 includes the following changes:
  • When Line Transparency or Ground Line Transparency is set to 100% in the KML section of the Flight Reader Options window, that line type will now be excluded from the generated KML file. This makes it easy to generate a KML that shows only the aerial flight path or only the ground-attached flight path. When both settings are below 100%, both lines will be included as expected.
  • Resolved an issue where invalid characters in ADS-B data could cause some flight logs to fail during processing.
