Flight Reader 1.8.11 released
A new version of Flight Reader is available. Release 1.8.11 includes the following changes:
  • Added Export Settings and Import Settings options to the File menu in the main Flight Reader window. These allow all configured settings to be exported to a file and later imported into Flight Reader from that saved file.
  • Improved mobile device location extraction to display the location of any DJI remote controller that contains a GPS receiver. This data is extracted into the APPGPS.latitude and APPGPS.longitude fields and is also displayed on the map with a blue “M” pin to mark the mobile device’s current location.
  • Added a new field named OSD.yawDelta to track the absolute change in the aircraft’s rotation (in degrees) between the current record and the previous record.
  • Added a new field named OSD.tiltInclinationDelta to track the absolute change in the aircraft’s overall tilt angle (in degrees), calculated from the aircraft’s roll and pitch angles, between the current record and the previous record.
  • Increased the precision of the OSD.tiltInclination field from 1 decimal place to 2 decimal places to allow for greater accuracy.
  • Rebuilt the photo extraction logic to improve the accuracy of detected photo locations and the total number of photos taken in the flight log.
  • Improved extraction of dual battery data when a second battery is recorded in the flight log.
