A new version of Flight Reader is available. Release 1.7.8 includes the following changes:
For drone models with dual batteries, the serial numbers for both batteries are now stored in the
SERIAL.batteryandSERIAL.battery2fields. -
Serial numbers can be found in the
RECOVER.*,DETAILS.*, andSERIAL.*fields depending on where they are extracted from flight logs. All serial numbers have been combined together and stored in theSERIAL.*fields. When referencing serial numbers, use theSERIAL.*fields as they now provide the most complete data. -
Added more size options to the Log Viewer Map Size setting in the General section of the Flight Reader Options window, allowing greater customization of the Google Map height in the Map log viewer.
Flight path markers on the Google maps are now only displayed when the home point is initially set or manually reset by the pilot. While small automatic home point adjustments, such as those made by drone models like the Air 3S, are still logged in the
APP.tipfield with “Home Point Updated” messages, they will no longer appear as markers on the Google map to reduce visual clutter.
