A new version of Flight Reader is available. Release 1.7.40 includes the following changes:
New Event CSV and Video CSV options are available under the Export menu. The Export menu will only appear in the context menu when selecting multiple flights and right-clicking in the main Flight Reader window.
A flight polygon KML is generated during flight log processing to visualize the flight area. Access this new KML by right-clicking a flight in the main Flight Reader window and selecting KML → Flight Polygon KML.
Added a new CAMERA.mode field to indicate when the camera is shooting in Single Shot, Multi Shot, Pano, or Video mode.
Added a new CAMERA.photosTaken field to show how many photos were captured. This value will be greater than 1 during rapid-fire photo modes like AEB or Burst.
Added a new CAMERA.panoPhotoSequence field to indicate the sequence number of each photo in a pano sequence. This can be used to group photos from the same pano sequence.
Rows are now highlighted in green wherever a new video recording begins in the Video Log.
The CAMERA.isPhoto field now logs a single photo entry at the moment each rapid-fire photo (e.g. AEB or Burst) is taken. The new CAMERA.photosTaken field shows how many photos were captured at that moment.
AM/PM designators are now automatically added to 12-hour time fields when using a Windows region that does not have them defined. In previous versions of Flight Reader, missing AM/PM designators made it unclear whether times were in the morning or afternoon.
The Measurement Units setting in the General section of the Flight Reader Options window now defaults to the user’s Windows region settings when this setting has not been set.
Resolved an issue that caused an extra photo to be incorrectly documented at the end of each pano photo sequence.
Resolved a crash that could occur when loading a malformed CSV file. Instead of crashing, Flight Reader will now display the malformed data. Reprocessing the flight log may fix the issue.
Resolved an issue where an incorrect flight start time could be shown when a second flight begins without powering off the drone between flights.
Fixed an issue that sometimes prevented flight logs from being processed when importing via File → Import Flight Log… in the main Flight Reader window.
