Flight Reader 1.7.26 released
A new version of Flight Reader is available. Release 1.7.26 includes the following changes:
  • Added the option to display the OSD.flyTime field in charts, allowing you to view the current flight time in minutes and seconds.
  • The flight map snapshot now uses OpenStreetMap as the default map source. To use Google Maps instead, you can enter your Google API key in the API Keys section of the Flight Reader Options window.
  • Resolved an issue where the After processing log file action (configured in the General section of the Flight Reader Options window) was not triggered when importing a flight log via File → Import Flight Log in the main Flight Reader window.
  • Resolved an issue that caused the Google Map to fail to load in the map window.
