A new version of Flight Reader is available. Release 1.6.3 includes the following changes:
Added support for processing Mini 4K flight logs.
When flight logs are synced using the “File” → “Sync Flight Logs” menu item at the top of the main Flight Reader window, TXT flight logs found on any Android devices (phone/tablet/DJI RC) connected to your computer will be automatically imported into Flight Reader. If Flight Reader is started after connecting an Android device, the TXT flight logs will be synced automatically when Flight Reader starts.
Note: Make sure your Android device is connected to your computer using a USB cable that supports data transfers (some USB cables are for charging only). For Android phones/tablets, choose the “File Transfer” USB mode when prompted after connecting the USB cable. For DJI RCs (with a screen), check that you have the latest firmware installed if you have any trouble transferring flight logs.
New settings have been added in the “KML” section of the Flight Reader Options window to set the width, color, and transparency of the ground line in the generated KML files.
Resolved an issue that was causing some flight logs to fail to process when flight log fields contained an empty value.
