A new version of Flight Reader is available. Release 1.6.21 includes the following changes:
Added a new “OSD.yaw [unwrapped]” field for easier visualization of aircraft yaw changes. This field shows the aircraft’s cumulative rotation angle, with positive values indicating clockwise turns and negative values indicating counterclockwise turns, reflecting total degrees turned in either direction.
Added an optional “Battery Times Charged” column to the Flight Reader main window. To add this column, right click the column headers and select “Customize Columns”.
Updated the “Flight Date” dropdown at the top of the Flight Reader main window to include the count of flights displayed in the main window.
Enhanced performance and precision of the fly time line drawn on charts when moving the mouse pointer over graphed lines.
Removed the Byte Order Mark (BOM) from the first line of CSV files generated by Flight Reader. This change ensures compatibility with CsvView and other CSV viewers that cannot process CSV files with BOMs.
Remember the last selected column sort order in the Flight Reader main window and improved performance when loading or reloading flights.
