A new version of Flight Reader is available. Release 1.6.14 includes the following changes:
Added Charts to generate line charts from flight data in the aircraft CSV.
Discovered the best local IP address for the Service Location displayed in the Flight Log Transfer service window.
Resolved an issue that prevented the aircraft CSV from auto loading into CsvView when the file path contained spaces.
Resolved an issue causing the “OSD.flyTime” field to be set to 0 when the last line of the flight log was still saving while the drone powered off.
Resolved an issue causing the “APP.tip” and “APP.warning” field values to spill into other columns of the Aircraft CSV when Windows uses “;” as the CSV separator.
