A new version of Flight Reader is available. Release 1.5.47 includes the following changes:
The columns in the map window can now be added/removed/reordered/renamed by configuring the “Map Log” fields in the “Logs/Reports” section of the Flight Reader Options window.
Added new “BATTERY.cellVoltageDeviation [V]” and “BATTERY2.cellVoltageDeviation [V]” fields to show the current difference in voltage among the battery cells.
Added new “RTK.aircraftAltitude [ft]” and “RTK.aircraftAltitude [m]” fields to show the aircraft’s current altitude as reported by the RTK module.
Added new “RTK.aircraftHeight [ft]”, “RTK.aircraftHeight [m]”, “RTK.aircraftHeightMax [ft]”, and “RTK.aircraftHeightMax [m]” fields to show the aircraft’s current or maximum height above the takeoff location as reported by the RTK module.
Updated the “RTK.baseStationAltitude [ft]” and “RTK.baseStationAltitude [m]” fields to display altitude values when negative. Previous versions of Flight Reader were hiding these values when they were below zero.
