A new version of Flight Reader is available. Release 1.5.22 includes the following changes:
Added a new “Map Data Resolution” setting to the “General” section of the Flight Reader Options window to allow all available flight data to be displayed in the Map window. By default, Flight Reader will use the “Show Notable Events Only” setting and exclude sections of the flight where there are no notable events or flight activity.
Added a new Sync History window to view the last 500 synced flight logs. Click the “Stop Syncing Aircraft Logs” button to stop syncing flight logs for a particular aircraft. The Sync History window can be accessed from the “File” menu in the main Flight Reader window or from the “Sync Flight Logs” section of the Flight Reader Options window.
When adding a new DJI account to sync in the “Sync Flight Logs” section of the Flight Reader Options window, you now have the option to assign a list of pilots to the account. When new flight logs are synced for that DJI account, those pilots will be automatically assigned to the newly imported flight logs.
Added an “Edit Account” button to the “Sync Flight Logs” section of the Flight Reader Options window to allow an existing account to be updated.
Added a “Date Range” option in the “Flight Date” dropdown in the main Flight Reader window to allow the flight list to be filtered by any start date and end date.
When right clicking a flight in the main Flight Reader window, you now have the option to generate a report for any start date and end date using the new “Date Range” option in the “Reports” menu.
Added tooltips to the column headers in the main Flight Reader window to explain what each column is displaying.
Choose the columns to display in the main Flight Reader window by right clicking any column header and choosing “Customize Columns…”. The column name and sort order can also be modified.
Greatly reduced the time it takes to open the Aircraft/Battery Log window. Most logs now open and display within a second.
Updated the grid padding/font/colors throughout Flight Reader to make them consistent.
Removed the BOM header from the generated GPX and KML files. While many GPX/KML viewers are able to read files with BOM headers, some viewers were failing to open GPX/KML files generated by Flight Reader.
Applied several fixes to resolve failures when processing DroneDeploy flight logs.
Resolved an edge case where the flight date in the main Flight Reader window is incorrect due to an invalid date and time value recorded at the start of the flight within the TXT flight log.
Resolved a possible case where flight logs could be skipped while syncing when DJI sends them down to Flight Reader out of order.
Resolved an issue where the buttons at the bottom of the Failed Flight Logs window would not display at some screen sizes with high resolutions.
See the release notes on the Flight Reader download page for a complete list of changes.
