A new version of Flight Reader is available. Release 1.4.8 includes the following changes:
Resolved an issue causing the “BATTERY.current [A]” field to display incorrect values for some older drone models.
Resolved an issue causing the “CAMERA.isPhoto” field to sometimes display “True” when a photo was not actually taken.
Resolved an issue causing speeds in the “Speed” column of the map window to sometimes display values that well exceeded recorded values.
Added “BATTERY1.timesCharged” and “BATTERY2.timesCharged” fields to the reports for drones using dual batteries.
Redesigned the top and bottom of the main Flight Reader window to give it a cleaner look.
Added new “File” and “Help” menus at the top of the main Flight Reader window to make it easy to access the most common features.
Use the new “File” → “Import Flight Log…” menu at the top of the main Flight Reader window to import flight logs by choosing the log files to import from a file dialog window.
An “update available” message will display next to the version number at the bottom right of the main Flight Reader window when a new version is available.
See the release notes on the Flight Reader download page for a complete list of changes.
