Fas registration??
New to flying drones. Was wondering what I need as far as licenses/registering my Phantom 3 Standard… Do I need to register with FAA? Do I need to take a drone course?? Any other documents?? Thank you all!
Check out this thread.
Can’t open page.
How about now?
Still cant
Most of what I shared in the above link is available here:
Thank you.
You might want to also log onto PhantomPilots, a Web Site dedicated to Phantom Drones , Link here…
Yes, you do need to Register your Drone and you do need some Training (TRUST)… As a New Drone Pilot, here are the Legal Things you need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
https://faadronezone.faa.gov/#/
Since you live in Somewhere in there USA, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Turn on the drone and watch it come to “life.” Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first time…
Lift off, 4-5 feet (1-1/2 meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Phantom 3 Standard, including the User Manual.
Fly On and Fly Safe…
Wow! That covers everything! Thank you so much!
