factory reset
Trying to do a factory reset on my mini4 pro. Seems stuck but daren’t stop it. been resetting for at least 45 minutes. Is there anything I can do
A factory reset on a DJI Mini 4 Pro typically takes only 1 to 3 minutes. If you are also clearing data or resetting firmware on the DJI RC 2 controller, it may take an additional 2 to 5 minutes.
To perform the reset process quickly and accurately:
On the DJI RC 2 Controller:
1. Swipe down twice from the top of the screen to open the Quick Settings.
2. Tap the Settings (gear icon).
3. Scroll down and tap System.
4. Go to Reset options > Erase all data (factory reset).
https://youtu.be/aRo0ryTgCuw
On the DJI Mini 4 Pro Drone:
Unlike the controller, the drone itself doesn’t have an independent interface. To reset the aircraft to factory defaults, you should connect it to a computer, open the DJI Assistant 2 software, select your connected drone, and choose the option to Restore Factory Defaults.
https://youtu.be/WbyS93tksxM
