I’m a new user. I took some time learning the basis flight controls etc before I started taking pics and video. All of the video’s that I’ve taken so are somewhat blurry. For example, the video I’ve linked HERE is pretty consistent with all the others. It was taken from about 90 feet, 4K and 3fps. I’d appreciate any suggestions.
I clicked on the link you posted and YouTube indicated that it was still processing it… This was 22-hours arfter your initial posting…
Sorry, for some reason the processing was stuck. It is available now.
It looks like it is stuck in Macro, but that is not possible… besides this video, did you shoot any other videos, like in your back yard, at various distances? Did you shoot any photos, if so what are the result from the other videos and photos?
I do not have a Mini 4 Pro, but here is a possible solution on this web site… You might also search this web site further if this does not solve it…
Adjust focal length? | DJI Mavic, Air & Mini Drone Community
Good Luck
Just to be clear. Did you adjust the focus on the screen prior to recording the video? Was the screen also blurry?
Are you sure your lens is clear (or your filter if you are using one)?
And with a follow on note, did your drone’s camera lens or the filters, if used, come with a protective film that is clear and difficult to see, but needs to be removed, so check for that too.
it should be auto focus. Are the cameras all clean? Sensor cameras as well ?might be a little something on the lens thats attracting its attention.
