Hi there,
I have crashed my P3Pro and it seems battery failed see attached log, but I have heard some people get lower voltage then mine 11V and aircraft still was ok anyway I broke gimbal arm and wire tape, ordered repaired. Now Drone is connecting to the remote control fine I can see live picture from camera and gimbal works as before but get lound beeping sound just after switching on the aircraft same as this guy here https://www.youtube.com/watch?v=p37-fF3Y-Kg . I have followed steps he showed without success, after few minutes my light go solid red on the gimbal.
What I noticed my battery seems ok I can charge it and light bars works fine but there is no data when checking on DJI GO App it shows 0% on all cells 0V all options seems disable.
Rest looks fine I can format SD GPS ok etc via DJI GO App
From SD Card hidden file “P3X_FW_LOG_AB” I have noticed few modules not deceted as showed below, but for some people in similar case reinstal firmware helped:
[00012604]========== remo-con disconnect. boot(15) ============
[00012681]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xe4dd0630].
[00012753]Packet upgrade start…
[00012836]Packet checking…
[00012908]Packet vlink 01.11.0020 ↔ 01.11.0020.
[00012985]Record vlink 01.11.0020 ↔ 01.11.0020 (flow = 0).
[00013059]Done.
[00013127]Version checking[1]…
[00025701][03 06][00] device not detected.
[00038271][03 05][00] device not detected.
[00038478][04 00][00] v1.48.0.0 → v1.48.0.0
[00051052][11 00][00] device not detected.
[00063621][11 01][00] device not detected.
[00076200][12 00][00] device not detected.
[00088774][12 01][00] device not detected.
[00101348][12 02][00] device not detected.
[00113930][12 03][00] device not detected.
[00114095][15 00][00] v1.1.2.0 → v1.1.2.0
[00126661][17 00][00] device not detected.
[00139231][17 01][00] device not detected.
[00139325][19 00][00] v1.0.8.96 → v1.0.8.96
[00139395][01 00][00] v1.32.5432 → v1.32.5432
[00139471][01 01][00] v1.32.5432 → v1.32.5432
[00139561][08 00][00] v0.13.0.7 → v0.13.0.7
[00139665][09 00][00] v4.1.0.0 → v4.1.0.0
[00139735]Packet upgrade failed at version checking.
Do you thing that can be just battery problem and that is why I get very lound beeping, and can not get it working?
Can not paste files here as I am newbi but link below
Thx in advance
