Prolem with dji fly app 1.19 to dji mini 5 pro. Point of intrest and home point H in my ipad mini. Hope they fix this…
I am sorry, I do not know what you are saying nor what you mean, too little information…
I am guessing that you are referring to the “Dynamic Home Point” feature, which is useful for flying from a moving location (like a boat). It may default to “on” or act unpredictably for you, leading to the home point being reset mid-flight without audio notification. Is this what you mean?
Here are some things you can do…
ALWAYS Check the Settings After an Update, ALWAYS!!!
After any app or firmware update, always navigate through your drone’s safety settings (including RTH altitude and home point settings) to ensure they are configured as expected, as updates can sometimes alter preferences.
In the safety settings, manually check if the “Dynamic Home Point” option is enabled or disabled, depending on your preferences… IF you do not know what I am referring to, Google it or search on YouTube…
If you intend to take off and land at the same location, ensure Static Home Point is selected.
If the setting seems stuck or is changing unexpectedly, try toggling it to the other option and back to “Static Home Point” to reset it.
That’s all I’ve got, also read you manual several times, you would be surprised what you missed the previous times…
