I recently bought a new remote control because the old one had a loose connection. Now I have the problem that the drone flies back when I return to home, but I have no way of stopping it in the app - the cancel button doesn’t appear. It only appears shortly before landing. Does anyone have any idea what the problem could be?
Without knowing what make and model of drone you are using, what controller you are using (if there is more than one option, what app and it’s version you are using, and possibly your location, it would be exceedingly difficult, even down right impossible, to offer you any advice.
But off handedly, I would ask is the new controller brand new or only new to you (as in second hand…), is it the same model as your previous controller and have you downloaded the latest version of your software app, and there may be special operations necessary to bind your old drone to the new controller.
Inquiring Minds Want to Know…
I’m assuming it’s a Mavic 2 since that’s where this topic was created.
You should be able to press the RTH button on the remote controller to cancel RTH. Did you try that?
Sorry… I forgot to mention it’s a Mavic 2 Pro. I didn’t try yet to press the RTH button on the controller but I will do so tomorrow. Thanks for your answer ![]()
