Recently, there has been issues with camera/picture quality using my DJI Mini 2. The camera shows colorful lines/dots on the phone screen when taking pictures. The colorful lines show more at different camera angles. Is this an issue with the camera? Do I need to send the drone in for maintenance? Is it a connection issue using the phone and new DJI fly app update?
Do those lines/dots also show up in the photos? If so, can you share a couple?
Example from a different angle. They are more obvious in the bottom right corner of the photo, but if you zoom in, you can see them throughout the entire photo.
Thank you for sharing those photos!
It looks like some type of hardware issue with either the camera itself or cables connected to the camera. Either way, it’s likely not an issue you’d want to attempt to repair yourself.
If you’re using old firmware, you might consider updating to the latest version. However, this doesn’t seem like an issue that would be caused by firmware.
You can find a similar issue here in the DJI forum:
Thank you!
