Hello,
I have a lot of flight log files. However, even CAMERA.isVideo column is True, CAMERA.filename is always empty. What may be problem ? I can provide example log files if you may.
Here the web site that used to decyrpt log files:
https://www.phantomhelp.com/logviewer
Best regards.
The software you’re using to generate those log files (e.g. DJI Fly) is not recording data in that field.
@msinger The software is dji pilot 2. Which softwares do record filename data ?
I’ve only seen that data logged in Map Pilot flight logs.
@msinger is there any way to overlay flight log and video without usin CAMERA.filename column. However, assume I record many seperate video in a flight and all videos is not supposed to be together every time.
I don’t have experience doing that, but I know some are using applications like DJI Telemetry Overlay for that purpose.
