after initialization back red lights stay on phantom 3 4k
I have a Phantom 3 4K I bought from a thrift store and a new issue with it now aside from the one it has had s9ince i first got it. The first issue it had when i got it was that the motors will only start if you are holding in your hand, will not start if you set it on the ground. Now after you power up the drone it goes through the blinking light process then it stops that and not only the front two lights that are supposed to stay solid red so you know your orientation iof the drone but the back two also stay on solid red as well and it is not wanting to start the motors even while holding drone in your hands. It does not have the camera so I am not able to connect it to the go fly app at all. which is okay with me because i enjoy flying it without the camera anyways. Anyone else ever came across these issues as well, and if so did you figure out a remedy?
