Hi all, have a MA2, I have been able to use active track 3.0 successfully, but have a couple of issues. 1. How do you keep the short tutorial from popping up when you go into active track? 2. When trying to select subject, when i hold on screen i get this horizontal and vertical graph instead of the green box. After attempting several times it finally appears. I noticed when the graph is present when i move my finger on screen the drone rises and lowers. What am i doing wrong or is this a bug in active track.
That graph is gimbal control. You are probably not changing the elevation of the aircraft but just changing your image. Make sure you have the green dot upper left of your desired selection before you draw the rectangle.
