Greetings, I have a DJI Mini 4 Pro. I want to activate Active tracker. The instructions say to go to settings, Control and after the drone is in flight activate subject scanning.
When I go to settings, Control I do not have a Subject scanning switch
MY drone is about 9 months old and all soft and firm wear is up to date any advice?
To activate flight subject scanning on the DJI Mini 4 Pro, first take off and fly your drone. Then, go to the control menu within the DJI Fly app and toggle the “Subject Scanning” option to enable it. Once activated, the drone will automatically detect and display plus signs (+) on trackable subjects in the camera view, allowing you to tap the plus sign to select the subject and initiate tracking,
I’m new to drone flying. I have a mini 4 pro. I think I’m following your instructions. I take off, fly 25 to 30’ away and up 15’. Then I go to the 3 dots, control, under “aircraft” “units”…Imperial, “Display Zoom”…Larger text. No toggle option listed as “SUBJECT SCANNING”. What am I doing wrong
My ultimate aim is to use ACTIVE TRACK. I follow directions to a T, I think. Every time I get to the final step, GO does not appear, but LIGHTING IN CURRENT ENVIRONMENT TO DARK. UNABLE TO USE ACTIVE TRACK shows up in the top left of my screen (bright sunny day). The camera doesn’t seem to be faulty because it takes beautiful videos. The drone has around 7 hours flying time. HELP, any ideas???
I figured out my problem. OBSTACLE AVOIDANCE system will not function with propeller guards installed. Therefore you cannot use ACTIVE TRACK because you cannot select your subject to follow.
Thank you for sharing that information… Is it in the instructions and you just missed it or did DJI just expect everyone to know that?
