Hi new flyer so help needed , i’m trying to download videos and pictures from my SD card to my PC but keep getting error messages. My microSD is an adapter which plugged into my USB port but when I try and transfer them, it just stops with an error message. Any help appreciated.
DJI mini 3
Hello Bluey2k.
Can you read the video footage and photographs via the controller when the Micro SD card is inserted into the drone? If so then the card reader may be the fault or the input port on the PC could be defective. If not then the MicroSD card may be corrupted. If your card is corrupted then you are bust.
An alternative issue may be the cable connecting the card reader device between the Micro SD card and the PC. It happened to me recently when connecting a device that required a cable or adapter. Try using a different connection port or a different card reader.
I’m not a tech guru but sometimes its the simplest things that cause the greatest problems.
Also as a last possibility check to see that your PC has all the latest updates for the relevant video and photographic programs.
Hope this helps in some way.
Best wishes.
Kevin aka Ancienttreehugger
Instead of taking the SD card out, have you tried connecting the drone directly to an USB port (it is not necessary to start up the drone). Make sure to use a compatible cable, as not all cables can be used.
