I am pretty sure this is just me missing something obvious. How do I resize the window when viewing a record? I want to see less map, and more log entries. I do not seem to be able to drag any kind of anchor around the screen to change the ratio of map to logs below.
You can resize the map by changing this setting in the Flight Reader Options window:
After changing this setting, you’ll need to reprocess existing flight logs to see the new map size.
Ok, that explains it. I need to reprocess the log, that is what I was missing. THANK YOU
