DJI Agras flight log txt
Hi,
I’m looking for an original DJI Agras flight log for development/testing purposes.
Ideally, I would like a DJIFlightRecord_*.txt from a DJI Agras T100, but a log from a T50, T40, T30, T20 or T10 would also be useful.
I’m specifically interested in the original encrypted flight record, not an exported CSV or KML. A log from an actual spraying/application flight would be ideal.
The flight does not need to contain any interesting event or error; a normal flight is fine. Location or other sensitive information can be from any test flight.
Would anyone be willing to share one?
Thanks!
Javier
I’m not sure if any of the Agras drones are still creating TXT flight logs. I know some of the older models did at one point, but I believe DJI changed something within the past year or so.
Everyone who has contacted me looking for these logs has been unable to find them on their Agras remote controller, which is where the TXT flight logs would normally be stored.
In that case, could you please share a sample flight log in whatever format the Agras generates it?
Thank you in advance.
I don’t believe DJI makes them publicly available, or at least I haven’t seen them available anywhere.
I see. Maybe someone could share one?
The Agras models must be storing a local flight log somewhere on the remote controller, since that flight data is uploaded to DJI SmartFarm once an Internet connection is available. My guess is that the local data is encrypted and unreadable, like much of the other data DJI stores on the remote controller.
Then, if it’s not asking too much, how do apps like Fight Reader do it? I thought they used those log files.
Flight Reader can only process DJI TXT flight logs. Some Agras models, or possibly older firmware versions, did create TXT flight logs, and Flight Reader can process those files.
However, that seems to have changed. Everyone who has contacted me recently about Agras flight logs has been unable to find TXT files on their remote controllers.
The commonly seen flight logs you’re seeking don’t seem to exist.
Then I guess apps like sprav.io use an API to communicate with DJI SmartFarm.
Do you know if there is a public or partner API available to retrieve Agras flight and operation data from SmartFarm?
I haven’t used that app myself. It’s possible they’re just scraping the flight summary data that’s displayed in DJI SmartFarm.
That feature will be available in the Flight Reader API next week.
OK, thank you for your answers.
@jluque the Flight Reader API is now able to process flight logs from DJI SmartFarm. You can find more details in the release notes here:
