Hi. When I view the SD card the folders are named 100MEDIA, 101FPLAN etc. I was wondering if there is a way to have the folders sorted and named as they appear in the flight app? So that e.g. Flight 1 on the app also gets stored on the SD card under one folder called Flight 1 - would reduce the time spent sorting through folders to select the ones I want to load to Pix4D. I’m using a Phantom4 with GS Pro. Thanks
No can do. Just sort them by date and time, and figure it out from there. However, you shouldn’t have more than one flight on the card anyway! You should be changing cards every time you change batteries, and formatting the card in the drone before flight, which would solve your problem, too!
That’s a shame - thanks for answering and for the tip on SD cards
